AEM EMS O2 Feedback options
Old Mar 25, 2017 | 02:48 AM
DiegoB16's Avatar
Show this prints below:
Old Mar 25, 2017 | 03:21 AM
markforrester99's Avatar
I would change the idle off if tp over to 4% and the idle on if TP under to 4%. What is your TPS reading in percentage when the throttle is closed and the car is idling?
I would then change the idle target base settings on the lower coolant temperatures to a higher value. Maybe 1500rpm until it gets to say 50c and then taper it down to what you want you want your idle to be.
You are using the AEM EMS V1 so im not overly familiar with its features. What is your O2 reading when the car cold starts?
Old Mar 25, 2017 | 04:42 AM
DiegoB16's Avatar
Tps closes reading 0,8 ~2% , and the afr , immediately after start cold engine is 0,7 but instantaneously change for 0,95.
Old Mar 25, 2017 | 02:22 PM
Sorry cant really help you any further. All you can do is change your idle settings to give it more revs and maybe reduce the amount of fuel as it seems like you might be flooding the engine and it struggles to idle
Old Mar 26, 2017 | 08:28 AM
DiegoB16's Avatar
I had the adjusts on tps and the rpm target 1500rpm, when the engine is cold, but the problem of the engine died after start, continue.
I thing with the problem of my engine is the ISC, because this problem don't occur every time. I believe with the ISC delay open some times and if I don't press gas pedal the engine died.
Exist any adjustments specific for the ISC for open earl the air pass?
Thanks again
Old Mar 26, 2017 | 12:44 PM
When the car is running can you see under the idle position section whether the setting is changing as the car runs? Are you 100% sure that idle control is actually working?
Old Mar 26, 2017 | 04:29 PM
DiegoB16's Avatar
Excuse me, I could not locate the section for I see is changing as the car run, do you should explain?
I dont sure if the idle control is working, I would like to confirme.
Old Mar 26, 2017 | 11:45 PM
Old Mar 29, 2017 | 05:20 PM
DiegoB16's Avatar
Hi Mark, I printed the tables in 3 conditions, I thing with the value of table position has a small variations,
Ignition on and engine off
Cold engine on:
Warm up engine:
Its correct?
Thanks
Old Mar 31, 2017 | 10:29 AM
Diego its hard to help without being there in person. I'm more familiar with the V2 EMS. The only thing i would do is add some more to the target idle at colder temperatures and see how it runs.
indi00
May 25, 2014 08:53 AM
s2kseven
Sep 20, 2012 01:56 PM
mrscbw
Sep 5, 2011 08:18 PM
RedLineS2k10
Sep 4, 2010 11:31 PM
EK9MAX
Jun 29, 2010 11:28 PM
