Does anyone use a map trim switch?
Old Sep 4, 2010 | 01:50 PM
RedLineS2k10's Avatar
Thumbs up Does anyone use a map trim switch?
I have a "map trim" knob as part of my instrument panel, i asked the original builder and he said its used to mess with the AFR qualities, well when i was on the dyno the tuner tried to adjust it, and there was no difference on the fuel map/AFR
Im assuming its not hooked up like a few other things, but its a simple turn knob, that rotates about 180 degrees left to right...Does any one use this, and if so what does it do?
Old Sep 4, 2010 | 09:34 PM
ap1tuner's Avatar
what aem are you using? aem ems? or what?
Old Sep 4, 2010 | 09:39 PM
dsddcd's Avatar
It sounds like it is a linear poteniometer, that was probably hooked up and used with a fuel trim table just like a temperature sensor.
I have never seen anyone do this b/c if the O2 feedback, fuel table and fuel trims is set up properly you should never need it.
Old Sep 4, 2010 | 11:31 PM
Im assuming its suppose to be hooked up to the AEM EMS 1052-u.......I called the builder and he said it was used to play with the AFR's..........I wonder if this was installed because of changes in altitude, etc...This was a formula D car at one point, and they travel quite a bit.....just a guess
DiegoB16
Mar 31, 2017 10:29 AM
indi00
Mar 7, 2012 02:16 PM
TerminatioN
Mar 7, 2012 04:37 AM
EK9MAX
Jun 29, 2010 11:28 PM
kial007
Apr 15, 2008 07:26 PM
