Aem ems v2 won't connect
Old Apr 11, 2015 | 12:32 PM
taifei's Avatar
Default Aem ems v2 won't connect
Just installed ems v2 but it doesn't seem to be connecting to the laptop. Following the instructions, I unplugged the stock ecu, plugged in ems, turned car to ignition, plugged usb cable. Now I am suppose to wait until a new hardware found msg to show but there is none. Tried with couple different laptops. The stock ecu works.
I've read that the first connection might require the use of the serial cable and an usb adaptor. Has anyone experienced this issue too?
Old Apr 15, 2015 | 07:21 AM
Ian300D's Avatar
When you have S2000 in ignition 2, as in ready to fire........your saying that with USB cable plugged in your not getting anything. Try opening your windows computer device manager and unplug and replug in cable. Does it show up with a yellow triangle. That means your missing drivers. Really though it's not hard to get AEM on phone with you and since your using a current model I'm sure they'll get you connected.
Old Apr 15, 2015 | 11:58 AM
taifei's Avatar
I bought a serial to usb adapter and it finally connected with that. I haven't tried the usb cable again after that, but I should probably test it out before I bring it to the tuner.
As for the missing drivers, the instructions says to wait until the computer detects the new hardware, then install the usb driver from the AEM folder. The computer was not picking anything up from the usb port.
When I used the serial to usb adapter, the computer recognized it right away.
Old Apr 16, 2015 | 08:03 AM
Ian300D's Avatar
You are right that you should test out USB before your tuner session. Any problems he has to fix generally causes frustration and money. Keep him on the single task of tuning.
bobonacus
Jul 23, 2017 03:39 PM
Mike's
Jun 13, 2017 01:46 PM
blink962
Feb 23, 2014 06:03 AM
Holeshot121
Oct 24, 2013 06:19 PM
ArchAngel2K
Nov 11, 2009 08:36 PM
