AEM Infinity gear ratio setup
Old Jul 14, 2020 | 06:46 PM
treimche's Avatar
Default AEM Infinity gear ratio setup
Does anyone have some values they would share to set up the AEM Infinity gear ratios? I understand not every car is the same, but I think it would be a great help to get started. Running a 4.10 Puddy Mod diff if it matters.
Old Jul 14, 2020 | 10:23 PM
afzan's Avatar
I believe the base map already has that setup?
Old Jul 15, 2020 | 03:34 AM
treimche's Avatar
My Infinity is from SOS and their base map does not have the gears set up.
Old Jul 15, 2020 | 06:26 AM
afzan's Avatar
Open up the s2000 base map from AEM and copy the gear table over
Old Jul 15, 2020 | 07:29 AM
treimche's Avatar
I will check that out, thanks for the suggestion!
Old Jul 19, 2020 | 12:22 PM
treimche's Avatar
@afzan thanks for the suggestion. I copied the AEM base map gear table and entered it into my current map and the gear position works......sort of. After 1st gear, its showing 1 gear too high. So once I'm into 2nd, it shows 3rd, once Im in 3rd it shows 4th, etc. I'll have to figure out where the break points should be since I'm running a 350z transmission and Dakota Digital speedo interface.
Old Jul 19, 2020 | 12:42 PM
afzan's Avatar
@treimche no problem. Does the aem see the correct vehicle speed in infinity tuner? it seems to have an effect also.
I haven’t tried this myself but it seems fairly straightforward:
https://www.aemelectronics.com/forum/gear-ratio-calculation
also there’s a video here:
https://www.aemelectronics.com/forum/setting-gear-ratios
Old Jul 19, 2020 | 01:00 PM
treimche's Avatar
https://www.aemelectronics.com/forum...io-calculation
https://www.aemelectronics.com/forum...ng-gear-ratios
Thanks a bunch for the links. I'll double check vehicle speed in AEM Tuner, but I do have the speedometer calibrated to within 1 mph of GPS speed according to the OEM gauge cluster.
Old Jul 19, 2020 | 01:46 PM
can2ki's Avatar
here what i have that works for me
Old Jul 19, 2020 | 01:52 PM
treimche's Avatar
Thank you. I'll compare that to mine to see if there is a difference.
