I'm using the latest version of Infinity Tuner (2.96.8592), but I do not see the newer ID1050X injectors listed. Is it critical that I get this exact or can I select the ID1000 injectors instead?
You should put in the injector data manually. At least you have the ID1000 for a lower bound reference. I put in my injector data (Grams Performance 550cc) and drove my car to Evans Tuning to get re-tuned. Jeff Evans tweaked some of the data (which surprised me, thought I was spot on). But injector pulse needed tweaking due to my skunk2 Ultra Race IM being for K-series but with an FtoK adapter... so the injectors were offset from the intake ports a bit more...
Anyway, a proper tune needs to also dial in the injector data.
