AEM Infinity - ID1050X Injectors Missing
Old Mar 15, 2019 | 06:21 PM
s2kvince's Avatar
Default AEM Infinity - ID1050X Injectors Missing
I'm using the latest version of Infinity Tuner (2.96.8592), but I do not see the newer ID1050X injectors listed. Is it critical that I get this exact or can I select the ID1000 injectors instead?
Old Mar 15, 2019 | 07:05 PM
s2kvince's Avatar
Disregard...just found the page in the manual that explains how to modify flow rates to customize.
Old Mar 15, 2019 | 07:09 PM
snitm's Avatar
You should put in the injector data manually. At least you have the ID1000 for a lower bound reference. I put in my injector data (Grams Performance 550cc) and drove my car to Evans Tuning to get re-tuned. Jeff Evans tweaked some of the data (which surprised me, thought I was spot on). But injector pulse needed tweaking due to my skunk2 Ultra Race IM being for K-series but with an FtoK adapter... so the injectors were offset from the intake ports a bit more...
Anyway, a proper tune needs to also dial in the injector data.
Old Mar 15, 2019 | 08:04 PM
afzan's Avatar
I got ID1050x injector data from AEM Support, the ID1050x have pretty different settings, here's a comparison below (both from AEM)
I can't remember why but I used all the ID1050x settings except for "fi open time" -- for those I used the ID1000 settings
Old Mar 16, 2019 | 02:50 PM
F1TwoThousand's Avatar
The exact settinga are on ID website:
just make sure the units are correct when entering. These will run like magic good choice on the injectors
Old Mar 17, 2019 | 06:02 PM
s2kvince's Avatar
Thanks all. Got it running today.
Do you know why the values provided by AEM support do not match the Injector Dynamics numbers? I used the ID numbers for offset and flow.
Also, is slope the same as flow?
I used the ID1000 numbers also for open time since I started to question the AEM numbers after seeing the variance.
UH-60DRIVER
Feb 19, 2016 09:05 PM
B0neSt0ck
May 13, 2014 06:48 AM
rikhemi
Mar 13, 2014 01:02 AM
broke 20
Forced Induction For Sale
Nov 17, 2011 04:57 PM
\\s2kris//
May 26, 2011 02:51 PM
