AEM Infinity Mounting inside cabin
Old Aug 30, 2019 | 07:33 AM
willis's Avatar
Default AEM Infinity Mounting inside cabin
I have the Infinity EMS, with the S2000 Adapter Harness. It's all hooked up and works really well. Now I have an EMS, and cables sitting on the floor by my feet! Does anyone have a way to mount this where the stock ECU goes, or some other place?
Thanks
Old Aug 30, 2019 | 08:24 AM
afzan's Avatar
AEM gives you velcro so you can stick it up where the OEM ECU goes, that's what I did, it's a bit of a challenge to get the big adapter harness behind the kick panel but you can do it with a bit of patience (easier said then done when you're crammed under there)
Old Aug 30, 2019 | 12:27 PM
willis's Avatar
Thanks! At least I know it will fit in there. Think I'll take the seat out first.
Old Aug 30, 2019 | 01:40 PM
afzan's Avatar
If you haven’t seen this already it has the exact instructions
https://www.aemelectronics.com/files...structions.pdf
looks like I missed the step about using the screw but I’m not getting back under there now.
Old Aug 30, 2019 | 02:05 PM
willis's Avatar
Thanks again for your help.
tommarkillie
May 9, 2019 12:50 PM
Rockin S2K
Nov 7, 2018 01:31 PM
Fabulous_omelet
May 21, 2018 08:06 AM
