AEM Infinity Mounting inside cabin
I have the Infinity EMS, with the S2000 Adapter Harness. It's all hooked up and works really well. Now I have an EMS, and cables sitting on the floor by my feet! Does anyone have a way to mount this where the stock ECU goes, or some other place?
Thanks
Thanks
AEM gives you velcro so you can stick it up where the OEM ECU goes, that's what I did, it's a bit of a challenge to get the big adapter harness behind the kick panel but you can do it with a bit of patience (easier said then done when you're crammed under there)
If you haven’t seen this already it has the exact instructions
https://www.aemelectronics.com/files...structions.pdf
looks like I missed the step about using the screw but I’m not getting back under there now.
Rockin S2K
Nov 7, 2018 01:31 PM
Fabulous_omelet
May 21, 2018 08:06 AM
