AEM map for OEM AP1
Old Jun 23, 2010 | 10:52 PM
Dollabill's Avatar
Default AEM map for OEM AP1
Hey!
I am using the AEM 1052, stock AP1, and need a oem cal...
I have looked in the AEM pro folder and couldn't find a single one for an s2k and wonder where people go for this information as the aem forums seem to be a mess....
I also searched this forum and found no results!
Thanks for your time!
Old Jun 24, 2010 | 04:58 AM
93turbo16's Avatar
The stock AEM AP1 Calibration is in the Startup Calibration folder -> Honda/Acura -> 1052.xxx
When you go to open it just hit the v.1.19 drop down menu for the file type at the bottom of the open dialog box.
Old Jun 24, 2010 | 09:14 PM
Dollabill's Avatar
Ooooo! excellent!
Thanks a ton! All the other ones are labeled by car/ engine so I was confused!
I'll see how she runs
Old Jun 25, 2010 | 05:23 AM
camuman's Avatar
Originally Posted by Dollabill,Jun 25 2010, 01:14 AM
Ooooo! excellent!
it should start, but you will still need to tune it. its not an oem copy map. its a base base map meant to get the car started. needs tweaking and tuning.
Old Jun 25, 2010 | 09:35 PM
Dollabill's Avatar
hmmmm
thanks!
yeah I'm using one the previous owner had, and its a little aggressive for stock. I actually realllly like it but I get some cam chatter when going WOT out of the powerband at low speeds
eg. I floor it in second at like 40 kph
getting it in for a tune asap tho!
thanks!
snmalone
Oct 4, 2014 02:29 AM
snmalone
Aug 5, 2014 12:32 AM
heist
Jul 28, 2014 05:12 AM
LukeS2K4EVA
16
Aug 3, 2010 11:47 AM
H Rev
Jun 9, 2010 07:41 PM
