whats the easiest way to...
whats the easiest way to tune my 2004 with a cai, test pipe and a amuse r1 titan. right now it is acting a bit sluggish at times. please let me know what i should do.
If it's sluggish, then it sounds like you are having issues with heat soak. The best way to deal with that is to get a Hondata IMG, colder spark plugs, higher pressure radiator cap, and change out your coolant with 80% water / 20% antifreeze.
Regarding the tune, your best bet depends on your budget. If you want to sqeeze the absolute most out of it, then AEM EMS or Hondata K-Pro is it. However, if you can find a tuner that is good with a Greddy E-Manage, then it would be the cheapest option that would give good gains.
Brian339
Dec 27, 2013 03:50 PM
