AEM series 2 cold start refining/tuning
As long as this has been moved to the top, where is the battery compensation? I can select different injectors but I can't find any kind of table for battery voltage compensation.
Thanks in advance...
It's called battery offset primary table
I just tried a v24 firmware basemap and it is Much improved compared to older versions.
I'm retuning tomorrow so I might have more to say after.
Sent from my T-Mobile G2 using Tapatalk 2
It has a lot to do with the behavior of injectors at different voltages. And each are different. 11 to 12v setting still needs to be right
There's a youtube demo on how they 'bench' the injectors in a controlled test to figure out how they react and then create a curve for it.
I just put in rdx injectors so I read about and learned some of the technicalities of how to deal with it in the ems and it would apply to stock injectors as well. The vendor provided bench results for them (they batch test and average) so I just had to enter the numbers into a table.
I think aem updated the basemap in this area so maybe they had analyzed stock injectors in a lab to get it right. It compared differently than my original map.
Send me a message with your e-mail and I'll send you my AEM Calibration. It starts down to 0 degrees F or so (but that cold I needed a car charger because a PC680 didn't have enough juice). I would up having to roughly double most of the fueling at lower temperatures. It seemed the AEM base map was great in California, but not so great in places where the weather gets cold in the winter.
Tim
Tim
Here are screen shots of my setup from AEM Pro and AEM Tuner.
[attachment=20453:Screen Shot 2012-05-15 at 10.46.36 AM.png]
[attachment=20452:Screen Shot 2012-05-15 at 10.45.08 AM.png]
[attachment=20454:Screen Shot 2012-05-15 at 10.48.03 AM.png]
Tim
Tim
Dang that's a low crank injector....barely 3ms, are you on stock injectors?
Nm you're on like 1000cc injectors no wonder
I'm at around 6000 with rdx injectors (410) I think it can be raised a little but I'm still playing with it
