AEM UEGO O2 in stock bung
Old May 13, 2018 | 01:37 AM
JonC's Avatar
Default AEM UEGO O2 in stock bung
Will the AEM UEGO sensor bolt up in the stock bung on the downpipe? Im interested in mounting one if I can do it in a way that doesnt require welding another bung on the stock header.
Old May 13, 2018 | 01:54 AM
flanders's Avatar
Yes it will fit in the stock bung.
But does your engine management allow you to run without the stock O2 sensor?
Old May 13, 2018 | 07:17 AM
JonC's Avatar
Im on a stock ECU, I thought these things had a narrow band output to connect to the stock ECU? At least this is what ive been reading on the forums. I dont see a point in running 2 O2 sensors if one will work.
Old May 13, 2018 | 07:32 AM
AP1Chief's Avatar
Stock ecu needs downstream ... or will run like crap.
Old May 13, 2018 | 07:39 AM
JonC's Avatar
Im just talking about the primary.
Edit. I should clarify. Im interested in a wideband to monitor my AF ratio. I was wanting to use the AEM UEGO sensor to output to the stock primary O2 input so that I dont have two redundant primary sensors side by side.
The secondary would be left alone and , from what ive been reading about it, it doesnt affect how the car runs - just monitors the health of the catalytic converter.
Old May 13, 2018 | 08:21 AM
flanders's Avatar
Yes some sensors do have a narrowband output, if yours do then yes it could replace the stock one with some wiring changes.
Given the somewhat unreliability of aftermarket sensors I would seriously consider welding on another bung before the cat.
If you take your cat section off it should be a pretty easy job.
You are correct about the secondary sensor, does not affect the car at all, it's just there to monitor the cat efficiency.
RAIN H8R
Dec 15, 2016 04:12 PM
Spoolin
Sep 28, 2016 11:32 AM
amdaman
May 12, 2015 04:05 PM
thanasis11
Nov 9, 2013 05:20 PM
CJB22
Mar 16, 2013 07:38 AM
