Primary o2 sensor fault
Old Nov 9, 2013 | 01:51 PM
thanasis11's Avatar
Default Primary o2 sensor fault
i have aem ems with the aem wideband, i switched to stock ecu to pass inspection but i get a check engine for primary o2 sensor fault. i looked under the car and both the wideband and stock sensors are on the header.
what could be the problem?
Old Nov 9, 2013 | 05:20 PM
chris_barry's Avatar
if its an standalone AEM wideband connected to the AEM ecu its probably connected to the same pin as the factory o2 sensor. Unplug the AEM wideband control box.
Best to remove unused sensors as running them when they are not connected to a wideband controller tends to soot them up.
chtmatthew
Feb 13, 2019 05:58 AM
Mike's
May 14, 2018 05:32 PM
Jaspah
Nov 5, 2015 01:13 PM
iDomN8U
Jan 20, 2013 08:50 AM
stevharr
Aug 29, 2006 07:36 PM
