Aem v2 cold start problem
Old Nov 8, 2022 | 07:15 PM
yzlovexq25's Avatar
Default Aem v2 cold start problem
Hi, everyone, I’m new to the community. After the car been tuned by Aem v2, every time I start up the car the idle is too low. Some times it will shut off when the engine is cold. I have to peddle the gas to keep it running until the engine warm up. I don’t know anything about tuning. Need help with this problem.
Old Nov 9, 2022 | 12:40 AM
noodels's Avatar
What rpm when warmed up ?
Old Nov 17, 2022 | 07:20 AM
WhiteSSP's Avatar
If you have no experience but want to learn, join Evans Performance Academy and watch his videos. I did just that and tuned my car from scratch.
If you dont want to learn or dont have the time/resources, I'd contact a tuner. It could be simple, but it could be complex. No way to know without knowing what your tune is now and how its setup.
But you should probably clean your IACV to be sure.
Old Nov 23, 2022 | 04:19 AM
RolanTHUNDER's Avatar
Has warm up enrichment been enabled? Do you know or can you see what the idle target RPM is set to? This could be the result of over-fueling when the car is cold. You will need to check the fuel table after you start the car cold or at least take note of what your AFR gauge reads, assuming that you have one.
Old Jan 21, 2023 | 09:40 PM
909s2k's Avatar
just hit up a tuner if you dont got the time, should be a simple fix as long as your car drives well after being warm.
AWWHITE s2k
Oct 6, 2023 06:19 AM
kantis123
Nov 19, 2018 08:03 AM
UH-60DRIVER
Oct 25, 2015 02:01 PM
palioxaraktiras
Κινητήρας - Μετάδοση - Περιφερειακά
63
Mar 24, 2010 08:04 AM
Muzzsjm
Jul 28, 2009 09:25 AM
