AEM v2 pin out question
Old Dec 3, 2013 | 02:35 AM
Rugby_Guy's Avatar
Default AEM v2 pin out question
Are any own switches (such as all the cruise control buttons) incorporated into the plug and play harness for AEM v2? For example, are the cruise control buttons on the steering column connected to the AEM through the PnP harness, and can they be set for things like nitrous control (bottle heater, purge, arm, etc) or could it be set to a 2-step enable switch?
Old Dec 17, 2013 | 04:50 AM
Rugby_Guy's Avatar
bump
Old Dec 17, 2013 | 05:08 AM
wadzii's Avatar
Banned
the only switch is the a/c switch but things have to be modified to use it for anything but a/c that switch doesnt work if you remove the a/c system. You have to rewire it.
You dont need a switch for 2step, you can disable the 2step based on MPH.
Ludeboye1
Mar 19, 2016 04:43 AM
liquidgsr
May 6, 2015 06:11 AM
jamie.1986
Nov 27, 2014 10:05 AM
cookies28
Jul 30, 2010 12:09 PM
