Any improvement with Hondata flashpro stock map?
Old Nov 30, 2011 | 02:57 PM
'ringmeister's Avatar
Default Any improvement with Hondata flashpro stock map?
I'm considering getting flashpro for my '09. my car is stock except for exhaust and HFC. I may eventually do an an e-tune, but for the time being I will probably just run the stock basemap. any concerns with doing this? I know that the peaks gains are nill but im interested in the lower vtec engagement, and higher rev limit.
For those who run the "stock" map, how do you like it? TIA
Old Dec 3, 2011 | 03:37 PM
Chris S's Avatar
subscribing, as I'm in the same boat
Old Dec 4, 2011 | 10:26 AM
Vitt's Avatar
I think you mean the "stock tune" reflash. It improves it a little bit. I still have a lot to learn about the Flashpro. I ran the Toda header tune with just a K&N intake and HFC and it is an AMAZING DIFFERENCE. I don't know if I was running too rich, so didn't keep it on that one until I install a header. But some people believe that the Toda reflash has more to do with the test pipe than the header itself. The HFC is somewhere between the TP and OEM cat. So if you get a decent aftermarket header you will be able to run a more aggressive tune with the HFC and exhaust. I would also get an intake. For now I am running the tune with the intake (I think it says Injen intake). Read up gernby's posts about soft dynos. He has a lot of info on the flashpro and tuning with TP, HFC, and exhausts.
Old Dec 10, 2011 | 09:50 PM
twinpnoy84's Avatar
Any more input? Im wondering this as well.
I just want to do mild mods as well.
Probably an intake (K&N), Berk HFC, a header, and a flashpro.
Old Dec 11, 2011 | 11:01 AM
xredjar's Avatar
Thats the beauty of the FlashPro, you get that first....then you use it to optimize your other mods.
It is worth having by itself. That being said, it's worth getting an e-tune done. It really improved the driveability of mine. If you add other mods after the initial e-tune, most will retune you for a small fee.
Check out www.e-tunez.com
I was the first S2000 they did, and I'm here to tell you....my car is worlds apart from where it started.
Old Dec 11, 2011 | 06:21 PM
//steve\\'s Avatar
Make sure that whatever you do choose you do some logging with it and make sure there isn't too much knock.
For me when I got it I was just running a TP and had 0 knock on the original factory tune. Toda reflash had a small amount of knock between 3-4000rpm at part throttle and the "stock" tune was the worst and had a lot more part throttle knock over a larger rpm spread. It was fine at high rpm WOT.
Old Dec 12, 2011 | 01:29 PM
Boofster's Avatar
Yes, stock for stock, the s2k does benefit from a tune.
This is similar to what you would get:
Notice the torque gain in the middle of the power band.
Drastically changes your car.
Old Dec 13, 2011 | 11:30 PM
NsaneR3vs's Avatar
Yes you will feel a huge improvement over the stock base map with the canned tunes. But it's best to get it dynoed by a good tuner. My tuner got over 30lbs tq and +30 whp in the mid. I gained significant tq in the lower end 3-4k. I got 135 lbs in that area. And a good tuner will get rid of that dip when vtec hits. My dyno plot is linear. Get all the mods you need and tune. Do it right once cus dyno tuning isn't cheap
andrew87890
Sep 16, 2013 11:09 AM
Mr. LEG
Jun 24, 2010 04:35 PM
soozookabluS2k
19
Oct 10, 2008 03:22 PM
nightcrawler7188
Jun 3, 2007 01:23 PM
jyeung528
Dec 11, 2003 04:18 AM
