AP2 Fuel Pressure?
Trying to rule out a lot of things because I’m throwing a lean code (PO171)
I currently have 41 At idle with FPR connected
and 45 with FPR Disconnected
cant seem to find any vacuum leaks but gnna check that with a gauge too if fuel pressure seems to be set correctly
Service Manual spec shows 47-54psi (00-05) "with regulator vacuum hose disconnected" and 55-63psi (06-and later). See pages 11-145 and later. Not sure the pressure tolerance of the gauge you're using and you're only 2psi low if your method is the same as disconnecting the vacuum hose. (We don't know what engine you have.)
-- Chuck
-- Chuck
-- Chuck
-- Chuck
Lol. It’s a 2005. So I assume it’s within spec then? I’m waiting for a vacuum gauge to come in to check for any leaks as well, couldn’t manually find any so I figured I’d start checking the fuel first.
mycrors4
Automotive builds
13
May 2, 2018 03:50 PM
nomadicS2k
UK & Ireland Meets & Events - Past
Jan 18, 2018 07:45 AM
Lovetodrive2000
May 9, 2016 10:18 AM
