Clutch a bit floppy at the top
Old Jan 8, 2018 | 04:07 AM
S2Bray's Avatar
Default Clutch a bit floppy at the top
Seems a number of elements of my car are choosing the post-Christmas cash depletion to rear their heads. Leaky lights, dodgy brakes and now this...
The clutch pedal has very little resistance for perhaps a little over half its travel, and even with the pedal fully depressed, slotting a gear requires a little more force it seems.I checked around the pedal and carpet for any signs of a leaky master cylinder, but seems dry, and the reservoir seems full in any case...Any other suggestions?
Old Jan 8, 2018 | 04:10 AM
jimmyb1978's Avatar
Mine gets the same symptoms with no obvious leaks, I just bleed it up every other year.
Straight forward to do on the drive/road and you can gravity bleed it if your on your own.
Old Jan 8, 2018 | 04:23 AM
S2Bray's Avatar
I'll try that first, thanks.
Can you recommend a fluid?
Old Jan 8, 2018 | 04:50 AM
jimmyb1978's Avatar
I cant recall which DOT rating you need but if you check the cap it may be DOT 4/5.
Heres the link for the gravity DIY
https://www.s2ki.com/forums/s2000-br...method-993927/
Old Jan 8, 2018 | 11:52 AM
tozerman's Avatar
Any DOT 4 brake fluid will do.
bleed full system
check clutch pedal height (as per workshop manual)
check there is zero free play in the pedal.
remove slave and grease the ball/cup, also remove any "nipple" on the ball end of the slave.
Refit everything and you should notice a difference
Old Jan 8, 2018 | 11:58 AM
BenRNBP's Avatar
Honda spec is DOT3 for the hydraulics ( you don't want to be using DOT 5 as that is silicone based ) probably good idea for the clutch as it's less hygroscopic than DOT 4 or 5.1 and you're not going to be cooking it hot like you might with the brakes.
A slave cylinder clean might be a good idea if the bleed doesn't help, the amount of grey mung that came out of mine was considerable.
Old Jan 8, 2018 | 12:01 PM
BenRNBP's Avatar
FTFY
bleed full system
curse loudly when you realise the piston has popped out of the cylinder and is now caked with driveway dirt
HvRRZ
Nov 16, 2019 07:54 AM
THMotorsports
304
May 13, 2019 05:49 PM
stack
Allegheny Classifieds
May 24, 2016 07:29 AM
GoOn3
Jun 9, 2011 12:17 PM
Yogi'sS2K
Jan 3, 2006 04:21 PM
