AP2 Haltech Basemap
Edit: Does anyone know if there is a difference for the trigger settings between an F20C and a F22C engine?
My intentions with the base map is to get the ECU and everything else linked to the ECU installed and running correctly before I mess with anything else, that way if anything goes wrong it'll be easier to eliminate variables.
The Elite 1500 came with both ESP and NSP software, both of which don't have an F22C base map. It did however come with an F20C base map, however I'm unsure if the trigger setup are the same.
Thanks for the polite and well intended response. I actually have a PTuning kit standing by that won't be installed until this summer, the car will be Etuned then. I just needed a F22C base map to play around with for the time being.
