AP2 Haltech Basemap
Old Jan 26, 2023 | 05:33 PM
highcam's Avatar
Default AP2 Haltech Basemap
Does anyone have an AP2 Haltech basemap?
Old Jan 27, 2023 | 04:48 AM
Chuck S's Avatar
There seem to be clues here:
Clues
-- Chuck
Old Jan 27, 2023 | 04:59 AM
highcam's Avatar
Clues
-- Chuck
Thanks for the passive aggressive response. I guess I'll load up the included clearly meant for an AP1 map into my AP2...
Edit: Does anyone know if there is a difference for the trigger settings between an F20C and a F22C engine?
Old Jan 27, 2023 | 06:17 AM
Chuck S's Avatar
"Passive aggressive?" I thought there might be some clues in that article you could use. Guess not.
-- Chuck
Old Jan 27, 2023 | 06:29 AM
kos's Avatar
kos
OP, who is going to be tuning the car? I would reckon that they may have a AP2 specific base map that they can send you to load, prior to the tune.
Old Jan 27, 2023 | 11:11 AM
highcam's Avatar
Thanks for the polite and well intended response. I actually have a PTuning kit standing by that won't be installed until this summer, the car will be Etuned then. I just needed a F22C base map to play around with for the time being.
My intentions with the base map is to get the ECU and everything else linked to the ECU installed and running correctly before I mess with anything else, that way if anything goes wrong it'll be easier to eliminate variables.
The Elite 1500 came with both ESP and NSP software, both of which don't have an F22C base map. It did however come with an F20C base map, however I'm unsure if the trigger setup are the same.
Old Jan 27, 2023 | 11:23 AM
highcam's Avatar
-- Chuck
Your response sounded a lot like "did you Google?", so I assumed that's what you meant. I've been on forums long enough to completely despise that answer.
Old Jan 28, 2023 | 09:33 AM
kos's Avatar
kos
Ahhhh gotcha. Have you tried reaching out to Haltech direct? I would be surprised if there wasn't a base map out there somewhere.
Oh danny boy
Aug 28, 2019 07:40 PM
