Best Piggyback/ECU for Changes in Altitude
I just purchased an 01 and was looking to do a few very basic bolt ons (air intake and test pipe) and tuning. I have been reading a lot of posts about tuning but I still have a few outstanding questions. I have narrowed my list of tuners to VAFC, E-Manage, Haltech Pro Plugin and, KPro. I see large changes in altitude with in a few arounds of where I live (sea level to 10,000 feet), which of these systems would be able to handle this as well as the stock ECU?
You'll have to rely on the stock ECU's definitions to account for any real altitude correction. Atmospheric pressure is lower at altitude and the MAP sensor alone will not be able to account for as it's only seeing intake. IE: Tuning at x pressure / y RPM at lower altitude will not 100% be the same for the same load and RPM when seen at higher altitude.
http://en.wikipedia.org/wiki/MAP_sensor#Example
IE: Tuning at x pressure / y RPM at lower altitude will not 100% be the same for tonme load oad oad and RPM when seen at higher altitude.
most good ecu's have a barometric pressure sensor built in.
I know with aem ems you can easily add a correction for baro... I do it all the time.
What you need to do is find a good tuner in your area that you trust and put whatever ecu in the car they recommend.
Originally Posted by urBan_dK' timestamp='1369763623' post='22571605
[quote name='yamahaSHO' timestamp='1369759700' post='22571451']
[/quote]
Yeah, I think we can both agree you are really reaching to say that the atmospheric pressure at the exhaust exit will have a noteworthy impact on how the car runs.
The thread title asks about the best piggyback ECU, certainly a full standalone with baro compensation would take you one step further to account for such minutiae as exhaust gas pressure vs atmospheric pressure.
But you also have to keep in mind that piggybacks all work on percentages from the stock ECU, so if the stock ECU provides a correction for these little details, so will the piggyback. It will just multiply (or diminish) the effect based on the percent change in the piggyback map for that load cell. If you do this in a standalone, you need to add all the barometric compensation logic yourself (as wadzii mentioned). Again - the stock ECU does this! No need to reinvent the wheel.
