Best Piggyback/ECU for Changes in Altitude
Originally Posted by urBan_dK' timestamp='1370380086' post='22586596
Yeah, I think we can both agree you are really reaching to say that the atmospheric pressure at the exhaust exit will have a noteworthy impact on how the car runs.
And who said anything about temperature compensations? I made no claims with regards to that. Emanage does have temperature compensation tables, though
I can tune as well as the next hack on this car. My original post said nothing other than MAP (speed density) being able to take into account altitude changes and hence it is better than TPS tuning in the case of a piggyback unit - especially considering our stock computer uses MAP as the load variable. You cannot argue that WOT will hit different load points at different altitudes and therefore will better be able to track with different atmospheric conditions.
You are welcome to throw all the Honda compensations in the OEM ECU out the window and do the same thing in a standalone if you want to. I for one, have found the OEM ECU does an excellent job of this.
As far as the bolded part: It will read pressure as it normally would, in the manifold. However, that is not the full story (as already explained) and not the end of final fuel calculation. If you get a chance to look at an OEM ECU running SD, you will see the tables that account for this. In some of Cobb's advanced tuning guides for AccessTuner Race and SD tunes, they explain how altitude has an effect even though the MAP is seeing changing pressures. If you had the ability to go in the stock ECU and zero out the additional changes, you'd would notice a change in the tune when changing considerable altitudes.
Have you tuned many OEM ECU's (not piggybacks)? I really don't have to explain this part as there is plenty of information out there. OEM ECU's across different makes isn't too dissimilar in how things are calculated, so it doesn't have to be specifically found for a Honda or S2000.
Summed up again... With a piggyback tuner, you will utilize OEM compensations for VE changes due to atmospheric changes when considering lower/higher pressure at the end of the exhaust. The Greddy will allow you to manipulate input/outputs for MAP and fueling to achieve desired results.
At this point all I can say is I'm not sure what we are debating. MAP is not the whole equation, correct, but due to the fact that the OEM ECU still provides the other parts (baro/IAT/Coolant Temp) you do not need to do all the speed density calculations and corrections within the piggyback. I stand by my statement that MAP-based tuning will be sufficient and better than TPS in the OP's scenario, and will get you a perfectly functioning tune at whatever altitudes necessary.
The original poster was talking about bolt-ons, we aren't talking about an exotic FI or ITB setup. Obviously, as things go further away from the OEM configuration the stock ECU is less able to correct.
Obviously a full speed density calculation requires more variables than MAP pressure, but those variables are accounted for quite well by the stock ECU. If you're going to standalone, you sure as heck better make sure the other variables are tuned for.
Hell ive been more then content correcting just off of TPS in NA config for sake of simplicity, but I rarely change altitude, and I think even then the tune may not be optimum there, but it will be safe.
dominion
Nov 24, 2009 02:48 PM
Spec_Ops2087
Jul 12, 2008 06:24 PM
Virus
Nov 6, 2003 06:22 AM
