Boost Solenoid
Old Feb 8, 2010 | 06:49 AM
GpWaP1 s2k's Avatar
Default Boost Solenoid
I searched and could not find any info as to what pin to splice for a boost solenoid. I have heard A4 or A6 I believe, but I wanted to make sure. Also how do you wire it up? Do you just splice it into the wire or actually cut the wire and solder the solenoid wire to KPRO wire? And where is a good place to wire the power wire up? Or what does it need to be wired to?
Old Feb 9, 2010 | 03:39 PM
JustinC's Avatar
It is pin A6
http://www.hondata.com/images/boostcontrol-diagram.gif
Old Feb 12, 2010 | 08:32 AM
GpWaP1 s2k's Avatar
that diagram says A11...
and do i just splice into that wire or do i cut the A6 wire and connect the boost solenoid wire to it?
Old Feb 12, 2010 | 08:39 AM
JustinC's Avatar
I know the diagram says A11, that is b/c its an older diagram for a different hondata ecu, but it applies the same. The pin is A6, that is why I stated it before I posted the diagram.
You cut the wire and wire it in according to the diagram.
Old Feb 12, 2010 | 08:42 AM
spectacle's Avatar
For the boost controller no need to go to the ECU...take the wires that go to the purge valve inside the engine bay. Not sure where the purge valve is anymore (since mine isn't hooked up and I forgot). On the drivers side find the big ABS unit. Theres a big wiring loom going into that...inside of that look there should be a small loom of 2 wires going towards the engine block somewhere. The wires are black and red with a yellow stripe. Snip off the connector going to the purge valve and connect up the boost controller wires to them, IIRC the wire order does not matter.
Old Feb 12, 2010 | 08:51 AM
JustinC's Avatar
thanks, I haven't wired that up yet, so wasn't sure about the harness routing
Old Feb 12, 2010 | 09:05 AM
spectacle's Avatar
SC's use boost controllers? Or are you just talking in general?
Old Feb 12, 2010 | 09:10 AM
JustinC's Avatar
Old Feb 12, 2010 | 10:25 AM
spectacle's Avatar
Man with you I never know lol
robs2g1
Aug 26, 2011 06:23 PM
siadam
Jul 3, 2010 08:59 AM
s2k aok
Jan 1, 2009 04:40 PM
owenxguo
Mar 30, 2004 07:46 AM
