Boost spike? datalog screen shot in thread
Old Jul 28, 2010 | 05:31 PM
DFWs2k's Avatar
per this:
http://forums.nicoclub.com/help-need-to-kn...ate-t81500.html
it does matter, i will switch lines tomorrow
Old Jul 29, 2010 | 04:49 AM
spectacle's Avatar
change your paramater back to "/psi and the boost resolution will be displayed correctly. The max threshold of 3 is good to go
Old Aug 7, 2010 | 10:20 PM
jaundice's Avatar
Your MAP sensor is showing 32 psi at that spike. Either your wastegate is sealed shut, or your boost controller is not working. I doubt you are tuned to run 32 psi on pump gas. Get it figured out before you boost again.
Old Aug 10, 2010 | 09:30 AM
Gernby's Avatar
Former Sponsor
Are you sure that your ECT sensor is connected well? I had a problem like this with my '02, and the solution was to just unplug and replug the ECT sensor connector.
EDIT: I didn't realize this is an old thread ...
admans2k
Feb 20, 2014 06:49 AM
1SlowSi
May 1, 2012 03:53 PM
1SlowSi
Apr 24, 2012 05:58 AM
2gr84u
Sep 8, 2008 07:06 AM
12gage
Oct 30, 2002 02:00 PM
