Can an 07 not use the honda kpro?
Sorry if this topic has been discussed before but I'm looking for an ems and I went on hondata's website and it said "The RSX ECU is not compatible with the 06-07 drive by wire, so the S2000 K-Pro cannot be used. Sorry." Any other options from hondata or should I get an AEM?
yes it will work on an '07. it a piggy back system that uses a rsx ecu piggybacked to the s2k's ecu. it's a cool system for the rsx - but not so for the s - you loose cruise control and other stuff. hondata discontued kpro for 06+ when the flashpro was released...
The k pro for s2000 is a dual ecu with your s2k ecu controling car functions and kpro ecu controling motor. Yes you lose cruise control but.. Who cares. You get more options over flash pro. Plus I got it for cheap
My car will be on the road with dual ecu in my 07 soon.
