Clutch problem
Clutch messed up
Clutch messed up
- #1
Sergons2k , Today 10:36 AM
so friday my 2006 s2000 clutch felt weird while driving it when ill put my foot on it it felt vibration so i checked my reservoir and it was empty and then pedal went all the way to the floor i put brake fluid from the gas station hoping ill fix the problem and no it didn't my pedal got super stiff and gears wouldn't go in at all so i was able to turn on my car and drive it back home using no clutch just gears falling in place at high rpms yesturday i replaced the master and slave clutch cylinder from a 2005 s2000 and pedal was not stif anymore but softer now softer then normal but comes up on its own when i was bleeding the lines i noticed loose ball barings about 5 of them inside the transmision bell housing and the engine block can anyone please help me out whats wrong with my car why my fluid went low why my pedal went stiff then soft after i replaced the parts and why there's loose barings in the bell housing??? Thanks
CarRamrod
Feb 9, 2016 03:27 PM
