CR shift light programming
Old Oct 20, 2010 | 01:04 PM
bluesaint's Avatar
Default CR shift light programming
Anyone with CR know if theres a way to reprogram the OEM shiftlight with flashpro? Since rev limiter is raised, the oem shift light became quite useless.
on a side note, anyone with flashpro /reflash using a good shift light?
Old Oct 20, 2010 | 08:35 PM
ihiryu's Avatar
I was actually thinking the same thing on my CR. Apparently it's a "power" light and not a shift light lol
Old Nov 1, 2010 | 09:27 AM
dedonderosa's Avatar
i know on the 8th gen si's you cant change the light, so i doubt you will be able to on the S
Old Feb 19, 2011 | 01:26 PM
S2K@PR's Avatar
did you bought the shift light?
I saw this one from Evasive http://www.evasivemotorsports.com/merchant...de=GIZZMO_SHIFT
There's also the shift beep from Modifry's. I personally prefer the visual shift light...
Old Feb 19, 2011 | 02:19 PM
steelers743's Avatar
from what i have read the RPM blink is built into the cluster thus unable to change
Old Feb 19, 2011 | 08:18 PM
AP2CRazy's Avatar
Its the max power indicator light. It would be nice to somehow program it as a functional shift light
Old Feb 19, 2011 | 08:19 PM
GrandMasterKhan's Avatar
Well, most all the S2000 clusters have an Alarm LED built into the cluster. This is actually the SAME LED which is used the CR but the CR uses it for a different purpose.
This makes me feel that there must be an input on the harness for the alarm LED. If anyone knows which wire it is I would be VERY HAPPY. It could be used for all kinds of cool stuff.
I personally want to set it as a VTEC notification (just so as to be 100% sure VTEC cams are engaged provided they are not audible)
Old Feb 20, 2011 | 05:25 AM
S2K@PR's Avatar
would like to know this as well
Since i have set my redline at 9k in the flashpro and dont know for sure when to shift before the rev limit.
Old Feb 21, 2011 | 07:14 AM
spectacle's Avatar
There's practically no way you can drive and DOHC Honda motor and NOT be able to tell when its engaged. ESPECIALLY on the S2k. Its impossible.
Old Feb 21, 2011 | 07:43 AM
w00t692's Avatar
The stock setup is exceptionally quiet with vtec engaged.
But you most definitely know you crossed over lol.
