CR shift light programming
Old Feb 21, 2011 | 08:32 AM
Mocky's Avatar
Originally Posted by AP2CRazy,Feb 20 2011, 01:18 AM
Its the max power indicator light. It would be nice to somehow program it as a functional shift light
I always wondered if this "max power" light is smart enough to know if modifications actually change exactly where the "max power" is.
Old Feb 21, 2011 | 09:10 AM
ans2k's Avatar
If it can. That must mean the ecu has an internal dyno program that is able to calculate hp. that would be awesome.
Old Feb 21, 2011 | 09:15 AM
Mocky's Avatar
indeed...and unfortunately, probably not the case
Old Feb 21, 2011 | 10:25 AM
GrandMasterKhan's Avatar
Originally Posted by spectacle,Feb 21 2011, 11:14 AM
There's practically no way you can drive and DOHC Honda motor and NOT be able to tell when its engaged. ESPECIALLY on the S2k. Its impossible.
Except when your supercharged/turbo charged and your vtec is set at 4000 or so
Old Feb 22, 2011 | 10:56 AM
S2K@PR's Avatar
i have Vtec at 3900. I'm NA by the way.
Old Feb 22, 2011 | 03:37 PM
cenix's Avatar
the peak power indicator light on the cr is probably the stupidest 'extra' thing on the cr. for those of you with a cr and flashpro with raised redline, does the light no longer stay on after a certain rpm past 8,200?
Old Apr 27, 2011 | 04:40 PM
ihiryu's Avatar
It just stays on no matter what it seems
Old Apr 29, 2011 | 04:43 AM
DFWs2k's Avatar
One of y'all take apart your dash/cluster and examine it, it's not too hard.
Just don't be in a rush and don't break anything.
Old Apr 29, 2011 | 06:47 AM
adrs2k's Avatar
I personally like have the power level indicator. First off, its pretty cool, especially at night. The whole cabin flashs and lights of green, kind of cool.
The other thing is I have used it quite a few times as a shift light, and it works well. It flashes, then stays on, then it goes off right when you should shift. Every time I use the light as a shift light I always shift right at the redline, and never fall out of vtec. Maybe its a coincidence, but its nice. I can just use the light to shift and I don't have to look down. Without an intake or exhaust on the car, its hard to just shift by sound...
Old Apr 29, 2011 | 02:55 PM
Harpoon's Avatar
I installed Modifry's shift beeper to chirp the first beep at the moment the shift light comes on. The shift light then becomes a warning to the third beep from the Modifry beeper to actually be right at the redline.
BrewCityBoozer
Nov 26, 2012 12:06 PM
nikthegrek
Κινητήρας - Μετάδοση - Περιφερειακά
Jan 12, 2011 03:38 AM
gravesdu_99
Aug 9, 2009 08:19 AM
Otto69
Jul 19, 2009 03:56 PM
esoteric
Aug 3, 2006 01:56 PM
