cranking issues w KPRO
Old May 23, 2010 | 12:34 PM
DFWs2k's Avatar
Default cranking issues w KPRO
so my car always has to crank for at least 5 seconds before it will start
if it doesn't start after the 5 seconds, then it will just keep cranking, and maybe eventually putter to life, then die
needless to say, this is pretty embarassing, do i just need to add fuel for cranking? on the "fuel trim" parameter, can i just insert a negative number? say, -2%? and if that fixes it, then it's all good?
Old May 23, 2010 | 07:02 PM
b.r.i.a.n.'s Avatar
this only happens on cold starts? try playing with the cranking base injector pulse. it's under the fuel trim under parameters. try increasing the value at -24 and -15.
Old May 23, 2010 | 08:34 PM
DFWs2k's Avatar
yea, if it's been running for a while, then i have to restart, it acts a lot better
Old May 23, 2010 | 08:36 PM
DFWs2k's Avatar
I don't have a -15, and it doesn't look like i can edit it?
Old May 23, 2010 | 08:41 PM
DFWs2k's Avatar
sorry, yes i can edit it, how much should i increase it? on a map i had that was working good, it's 77.34, and this is 66.58
Old May 24, 2010 | 08:15 AM
b.r.i.a.n.'s Avatar
there is no set amount. it all depends on the injectors and the fuel you are using.
in your case it seems like it wants more fuel. so i would increase the first two values by 5ms and see what happens.
this is all trial and error. keep playing with it till it gets better.
Old May 24, 2010 | 08:46 AM
spectacle's Avatar
If you have ID 1000's I have some parameters that will make the car start every time, but I still need to tweak the warm start settings to get it to start up like factory. Cold start starts faster than factory.
Old May 24, 2010 | 09:19 AM
DFWs2k's Avatar
i do have ID 1000s
Old May 24, 2010 | 10:04 AM
spectacle's Avatar
I'll send you the parameters later tonight
Old May 24, 2010 | 10:06 AM
DFWs2k's Avatar
ok, thanks
