cranking issues w KPRO
ok, it's good as long as I prime it and then crank it, haven't tried just turning key and then cranking, but i'm fine with having to prime it
i don't know if what i am doing (priming fuel pump for the 1000cc injectors) is necessary or if i am just doing a bandaid fix?
also, i was low on gas, came off the highway after driving for about an hour or 2, stopped at a gas pump (wrong f'n side of the car), and went to start it to move it, and it didn't start, i am hoping that was just due to being low on fuel and it being hot? i let it cool down for about 10-15 minutes, then got in, primed it 4 times, and it started up
can you send me your kal, or send me a screenshot of your fuel trim page
I am running similiar settings as spectacle, since we worked on them together. Although on some really hot starts I have to hold the start button a little longer, it is way better than stock settings. I want to see some other things first, which is why I want to see your kal before I say anything.
JUSTINTHECOASTIE
Aug 9, 2017 10:52 AM
