Decel Popping/Lean mixture
Old Aug 24, 2010 | 01:10 AM
deibit's Avatar
Default Decel Popping/Lean mixture
So.. again my setup
- EDM MY08 (F20C DBW)
- Giles eManage Ultimate BADAS Black (with wideband feedback)
- ASM 07 Header
- Berk HFC
- Tanabe Concept-G exhaust
- NGK 1step colder plugs (OEM Gap)
- Okada Coilpack
When I open the throttle (cruising) the A/F is somewhere around 13-14ish values
When decelerating the A/F goes very much to the lean side (20ish). And the exhaust does the usual "Harley Davidson Style" popping (mild-normal one.. no explosions or flames involved)
Should I consider it normal? (I'm concerned because of the car going that lean in decel). I know that we should expect that the injectors are not working when the throttle is closed, but somehow I expected the ECU/eManage to compensate it by keeping them open a bit longer..
Old Aug 24, 2010 | 04:16 AM
chris_barry's Avatar
My psychic diagnosis is you are getting some air into our exhaust system allowing the lean over run mixture to ignite.
Do you headers have slider joints or are there any leaks through flange joints?
Old Aug 24, 2010 | 05:31 AM
deibit's Avatar
I do not get any pops at full throttle and just some pops at middle throttle (from time to time). Most of the pops are just in decel (but not exagerated.. my car sound like most of the tuned cars over there)
We did change all the gaskets when we installed the header, HFC and the eManage (header to engine, header to HFC and HFC to exhaust) we even changed the header to engine bolts.. so I am almost confident that there's no leak...
Old Aug 24, 2010 | 06:23 AM
Gernby's Avatar
Former Sponsor
I've grown to LOVE the gurgles and pops that my exhaust makes while engine braking.
Old Aug 24, 2010 | 08:36 AM
spectacle's Avatar
The injectors shut off during decel, the AF reading is completely normal. All cars do this
Old Aug 24, 2010 | 08:48 AM
DBXFX's Avatar
^^^ I agree
You're just pumping air when in gear and decel.
Old Aug 24, 2010 | 09:46 AM
H22toF20's Avatar
what he said.
My exhaust doesn't make any popping sound under deceleration
Old Aug 25, 2010 | 01:07 PM
ap1_tot's Avatar
Originally Posted by H22toF20,Aug 24 2010, 09:46 AM
what he said.
haha you should be happy otherwise you'd wonder what it is and get all paranoid. well that's what i'd think.hahaha
Old Aug 25, 2010 | 01:22 PM
urBan_dK's Avatar
The EMU is not as vigilant as OEM when turning off the injectors on throttle off. I have run my car (with a WBO2 in place) and while it takes less than 1/2 a second to go full lean according to the WBO2 without the piggyback, it takes 1-2 seconds with the EMU in place.
It's just one of many warts of the EMU solution.
EOE
Oct 1, 2012 10:39 AM
deibit
Jul 23, 2010 02:19 PM
Hero
Mar 2, 2010 05:44 PM
Mondo
Feb 23, 2010 10:36 AM
AusS2000
Dec 17, 2003 02:32 AM
