Does aem require a retune for cold weather?
Old Nov 2, 2012 | 05:25 PM
AWWHITE s2k's Avatar
Default Does aem require a retune for cold weather?
I'm having fire up issues. Aem/tune is 3 months old was tuned in 1 of the last days of summer. Car fires up fine first time. But if I go to the store and turn car off the car will not start back up till car is cold again.
Old Nov 2, 2012 | 09:59 PM
liquid_helix136's Avatar
warm starts are known to be an issue, Ill load up my tune and see if I can find the two tables that need to be changed with the values
Old Nov 2, 2012 | 10:08 PM
Start Extra Decay Table (Fuel > Advanced Fuel > Fuel Trims > Start Extra Decay Table
for coolant temp vs S I have
158 = 13.35
176 = 13.35
194 = 13.09
212 = 10.73
230 = 6.02
248 = 0
And the other table is Start Extra vs Temp table
I have these at
158 = 20.51%
176 = 19.53%
194 = 14.65%
212 = 9.77%
230 = 8.79%
248 = 6.84%
This fixed my hot start and lean upon hot start issues (idling in the 16s if o2 FB was turned off)
Hope this helps
Old Nov 3, 2012 | 07:26 AM
sata3000's Avatar
which aem do you have? 1052? or v2?
Sent from my Galaxy S II using Tapatalk
Old Nov 3, 2012 | 08:11 AM
I went alil over kill I have the v2 Ems with stock motor with K&n intake/header/stright pipe and exhaust+tune made 216hp on mustang dyno I wish there was a way to upload videos from my iPhone to on here so u guys can see what it's doing.
I get car from tuner it works fine till I drive all way home 1-1/2hours later then I notic my car f@#king up everytime
Old Nov 3, 2012 | 12:57 PM
stuff i posted was for AEMpro for a V1, might not apply to you. Idk
Old Nov 3, 2012 | 03:45 PM
ok
welll i tryed to push gas pedal down wile starting up u can hear alil fire up happen but not enuff to get the motor running like struggling so i am guessing i'm having a fuel issue
jh4db536
Oct 28, 2017 07:27 AM
UH-60DRIVER
Oct 25, 2015 02:01 PM
AWWHITE s2k
Nov 2, 2012 12:50 PM
Metcalfe
Sep 10, 2011 07:57 AM
TJTURBO
May 22, 2007 06:56 PM
