Dyno/tune gone wrong
Old Oct 3, 2013 | 03:09 PM
S2SICC's Avatar
Default Dyno/tune gone wrong
Guys I'm really frustrated and upset don't know what's going on.
My mods are custom 3.5 intake
Skunk2 megapower header
Skunk2 megapower exhaust
Skunk2 70mm TB
And an emange ult for tuning.
When they got it on the dyno my baseline was at 190.3 on a mustang dyno.. And that didn't seem right to me. On top of that I couldn't even finish my tune because when my tuner hooked up the emange ult. And did a baseline with tht it was all wrong. He stopped the dyno because he said there was sumthing wrong with the emange ult. It was like crazy swiggly lines. While my oem ecu wasn't all tht swiggly. Please help don't know what the problem could be
Old Oct 3, 2013 | 03:13 PM
Manga_Spawn's Avatar
Site Moderator
Is it set up correctly? There are things inside the unit that have to be set up correctly (I wish I had more detail for you but someone will chime in).
Old Oct 3, 2013 | 03:21 PM
S2SICC's Avatar
Yes my tuner set everything up. Cleared up the turbo base map. And set everything at 0 so he could tune but when he did the base run. It was majorly swiggly. I will try to upload a picture if possible I'm using iphone
Old Oct 3, 2013 | 06:10 PM
Kermdaddy's Avatar
We will need more details.
Has your tuner used EMU before?
I could be mistaken but I thought the skunk2 header lost power vs oem
Do you have a baseline?
Also moving to proper section.
Old Oct 3, 2013 | 08:27 PM
S2SICC's Avatar
He has used emu many times he told me it was the second time he it had happened to him like this. He told me to get the emu checked out told me there might be sumthing wrong with it so I'm probably gonna send out to greddy.
I do not have a baseline but I made 190.3 on the baseline I'm guessing the very first run he did. Then it jumped to 210.6 when he hooked up the emu but it was not running right. Where was this post moved to?
Old Oct 3, 2013 | 09:25 PM
flanders's Avatar
Lots of info that you might want to check in this thread https://www.s2ki.com/s2000/topic/408...-ultimate-101/
Old Oct 3, 2013 | 10:10 PM
S2SICC's Avatar
I don't know it it was the emu. But on the graph the parameter was bouncing around like crazy
Old Oct 4, 2013 | 04:31 AM
wadzii's Avatar
Banned
Throw the emanage away and get something you can actually tune the car with. It amazes me that these things are still around.
Old Oct 4, 2013 | 05:59 AM
S2SICC's Avatar
I mean it's what I can only work with as of now..
I jus wanna know what the problem is
Old Oct 4, 2013 | 08:33 AM
S2SICC's Avatar
I mean honestly is there anyone out there that has had same problems as me. Trying to find the solution here.
