Which ECU to buy Please advice
Old Mar 10, 2010 | 01:50 PM
JC_S2000's Avatar
Default Which ECU to buy Please advice
I'm working on getting a turbo for my AP1 (around 330hp) and i need to buy a ECU what i was told by a good friend is to get the Kpro from Hondata because he got a bad experience with AEM, my dilemma is that the Kpro is $1750 which is way out of what i was thinking to spend on a ECU.
Is there a big difference on getting a different ECU any brands, recommendations or personal experiences, any help will be greatly appreciated
thanks in advance
Old Mar 10, 2010 | 02:22 PM
DFWs2k's Avatar
first off, is emissions an issue?
who are you going to have tune it? call and ask them what they prefer
Old Mar 10, 2010 | 03:29 PM
crazysupratt's Avatar
i agree...whatever your tuner has experience on.
Old Mar 10, 2010 | 03:33 PM
73Zero's Avatar
Being that you're from Miami (according to your user info), you won't have to worry about emissions (like we do here in Cali). Therefore, you don't HAVE to go with the Hondata, if it's cost you're concerned with.
You might wanna mention what your goals are, and whether you're going All-Motor or FI. That way, those of us with experience using those ECUs with that type of engine setup can chime in.
Regardless of which ECU you go with, as long as you go to an experienced tuner, then you should be good to go.
Old Mar 10, 2010 | 03:40 PM
JC_S2000's Avatar
that's right no emission in miami, goals is to just to make over 300hp at the wheels i want to keep it safe, my car is a show car but i don't want to go too much boost and blow the engine, thanks for the advice guys so pretty much i'll go around shops and ask what they prefer/work or best experience on which ECU
Old Mar 10, 2010 | 09:35 PM
nicks2k2000's Avatar
It all depends from what I know hondata is a great system I hear easy to tune I got an estamite to tune my 2000 s2000 I was told 400 for hondata and 600 for aem problem with handata k pro u have to replace some sensors I was told but I agree with it all depends on the one tuneing it if u find a good tuner recomended by alot of ppl find out his preference cause that's the better job he does then
Old Mar 11, 2010 | 05:40 AM
Gernby's Avatar
Former Sponsor
What a word dump. Are the punctuation keys missing from your keyboard?
@ OP, I would do some research to make damn sure your county is not going to start doing any sort of OBDII testing for annual inspections any time soon (or before you plan to put it back to stock).
Old Mar 11, 2010 | 07:05 AM
wadzii's Avatar
Banned
find a tuner you like and trust, use the system they want you to use.
they are all very capable and will run the car well.
Old Mar 12, 2010 | 08:24 AM
camuman's Avatar
psh this one is easy. AEM EMS and MASE TUNE!!!!!!
pm him, mase engineering, he comes down to miami ussually once or twice a year. hes worth it....and is very reasonably priced!
tell him anthony sent you!
Old Mar 12, 2010 | 12:40 PM
josh7owens's Avatar
I also have been thinking about this some, Im between aem and kpro. My thoughts are that kpro doesn't have the start up issues or anything like the aem. (from what I read)
I'm in ky so we have no emitions what so ever
