engine valve simple question HELP!!!
Old Jun 23, 2020 | 08:14 AM
salte21's Avatar
Exclamation engine valve simple question HELP!!!
are the valves vented?
the crank turns 720 deg for every 360 on the cams. so when i put my engine back together i was actually 180 deg off from TDC on the cams. I tried turning it over. will my valves be bent??? or are they vented?? thanks a lot for any help
Old Jun 24, 2020 | 04:46 AM
treimche's Avatar
What do you mean by "vented" valves?
Old Jun 24, 2020 | 05:14 AM
salte21's Avatar
Honda says they are interference engines. But when the cam sensor is unplugged, engine will turn on. Found out the cam timing was off by 180 deg. I put the cams in with the marks pointed at each other so only explanation is that I turned the crank to 360 not a full 720 deg when setting up cams for TDC. Compression seemed normal, wanted to know if my valves were toast. Took to a mechanic and he said they should be fine but are gonna check the head. Gonna cost me a pretty penny, so I wanted to ask the forum
Old Jun 24, 2020 | 05:15 AM
salte21's Avatar
technician said If they were vented or not, I’m not sure what that means either. Made me suspicious to what he was tryna tell me
Old Jun 24, 2020 | 06:51 AM
Chuck S's Avatar
Found a patent drawing for a vented engine valve. Little valve inside the big valve on the right. We don't have them, nor do I see how it would matter if the cams are not set right and the valves are set to strike the pistons.
-- Chuck
Mr. W
Jan 28, 2019 02:48 AM
xpressive
Dec 13, 2016 03:45 PM
m1bjr
Car Talk - Non S2000
20
Oct 22, 2016 07:35 AM
BoostedE21
R&C Parts For Sale
May 9, 2016 09:58 AM
