Engine won't start error code: p0335
Old Nov 27, 2015 | 07:08 PM
LiveFast's Avatar
Default Engine won't start error code: p0335
Just replaced timing components. Trying to start engine and getting crank position sensor signal error (P0335)
But the car is logging rpms while attempting to turn the engine over.
Checked for voltage in the pins off the harness had 5 volts ground and 12 volts on the positive ends
Running V2 Kpro.
Car is a 2004 ap2.
Car was running before we took it apart.
Any thoughts on a resolution?
Old Nov 28, 2015 | 10:27 AM
ninetysixyenko's Avatar
Is the position wheel facing the correct direction? It is labeled "OUTSIDE" on one side. Did you buy the sensor new or used?
Old Nov 29, 2015 | 07:43 AM
s2kt3's Avatar
Almost 100% it has to do with the jumper harness or the connections on the board where the jumper harness attaches
Old Nov 29, 2015 | 08:16 AM
afzan's Avatar
Check the small Hondata provided harness. Mine had pins that were not crimped properly , pull each wire and see if the wire comes out easily,if so then recrimp the wire onto that pin
Old Nov 30, 2015 | 08:53 AM
LiveFast's Avatar
It was a simple fix.
Had the cam sensor and the crank sensor swapped.
Smh.
We fixed it that night
benjy_b
Feb 14, 2014 02:14 PM
AZ-S2000
Mar 23, 2013 05:13 AM
TRD_Celica
Jan 23, 2013 08:42 AM
Popa
May 15, 2010 08:14 AM
PistolPete76
Mar 18, 2010 08:29 PM
