F20C2 AEM stock base map anyone?
Old Oct 11, 2012 | 11:45 AM
Buzz2K's Avatar
can i use the base map to break in the car after rebuilding the engine almost to stock OEM specs??
Old Oct 24, 2012 | 06:17 AM
liquid_helix136's Avatar
The aem base map is a pretty rough estimate map. You will run very rich, drivability won't be very good and your fuel economy will suck. It's pretty easy to tune an N/A car once you figure out how it all works. Pretty much follow what jh4db said and you should have a half decent map
Old Oct 24, 2012 | 03:57 PM
timg's Avatar
The AEM base map was actually dyno tuned by a well known tuner... It is rough in places (the fuel trims need a lot of work), but is a great place to start. You will be fine running a near-OEM setup with it.
I found the AP1 base map ran lean on an AP2 (not surprising). 10% more fuel and it was spot on. The fuel economy was in the high 20's.
With that said, I didn't find great fuel economy and smooth/consistent low-load tuning until I went boost comp. The extra resolution offered by boost comp is very nice.
Tim
AlpineFD
Aug 16, 2018 12:37 PM
SickoS2K
May 5, 2014 04:39 PM
mrscbw
Sep 10, 2011 12:18 AM
lotus7racer
May 25, 2010 06:03 PM
Nhan
Dec 6, 2006 08:08 PM
