Flashpro on an AP1. Is it possible?
Old Apr 11, 2010 | 07:28 AM
ap1_tot's Avatar
Default Flashpro on an AP1. Is it possible?
Is it possible to convert an AP1 F20C to work wit a flashpro? Like maybe converting it into DBW and probably, use an ap2 ECU?
Or is Hondata currently making a way to tinker wit AP1s using a flashpro? thanks guys.
Old Apr 11, 2010 | 07:41 AM
dstevens's Avatar
This has been covered before; the 2005 and earlier ECU does not use flash memory - is not re-programmable.
To upgrade to a FlashPro you would essentially need the whole wiring harness of an AP2 (engine harness, under dash harness, throttle controller, o2 sensor wiring, diagostic connector ...) plus the DBW throttle pedal & throttle body and the engine sensors from the 2006+ (crank and cam sensors, valve cover). There may be some more items, but I think you get the idea - you'd need a donor 2006+ and then swap everything over to the earlier chassis.
Old Apr 13, 2010 | 07:43 PM
96-EJ6's Avatar
K-Pro for 00-05's
FlashPro for 06-09's
Capabilities and features are nearly identical.
S2000 K-Pro
Old Apr 15, 2010 | 10:49 PM
73Zero's Avatar
Originally Posted by 96-EJ6,Apr 13 2010, 08:43 PM
K-Pro for 00-05's
Yes...but unfortunately, the pricing is not.
To the OP, it's probably not worth the trouble to completely convert your car over to the DBW-spec S2K...it's seriously a lot of trouble you'd put yourself through just to be able to run a FlashPro.
If you were looking to go with a Hondata tuning solution for your AP1, then the only route you can go is with a K-Pro.
Old Apr 20, 2010 | 08:38 AM
ap1_tot's Avatar
Okay thanks sirs. Downside of the K-pro though is it costs x3 the price of the Flashpro haha
Old Apr 20, 2010 | 10:16 AM
73Zero's Avatar
Haha, I feel your pain. I'm saving up for the K-Pro too.
ktwenty
Jul 2, 2019 08:36 AM
SkywastheLimit
May 22, 2011 10:41 PM
BuBuS2k
Aug 12, 2009 07:28 AM
s2ksang
Apr 8, 2009 03:57 PM
s2ksang
Feb 26, 2009 09:45 AM
