FlashPro, can a rich overrun be utilised?
Old Jun 6, 2010 | 02:27 PM
Dan1987's Avatar
Default FlashPro, can a rich overrun be utilised?
Good Evening,
i have ordered a flashpro and i was just wondering if a rich overrun could be utilised with the software in order to help with piston cooling for forced induction inparticular? I know that the injector duty drops on overrun to pretty much zero, but i know alot of modern cars fueling systems are set-up so that the injectors fire every say 20 crank revolutions on overrun to help keep the cylinders warm to maintain fuel atomisation efficiency. Is this the case with the S2000 (F20c)? if so, is it possible to widen the pulse width within this area of the map to throw in a large amount of fuel to bring piston temps down?
Many Thanks
Dan.
Old Jun 7, 2010 | 02:04 AM
s57_s2k's Avatar
Of course , it is a tuning software you can control fuel , spark and more . you can do what ever you want . you can run rich , lean and you can blow your engine .
Old Jun 7, 2010 | 07:31 AM
Gernby's Avatar
Former Sponsor
I don't believe you would be able to do this with the FlashPro. Unless you disable closed loop operation, there's very little you can do with fuel at zero throttle.
Jaspah
Feb 4, 2017 12:12 PM
DFWs2k
Jan 10, 2013 10:18 AM
dyhppy
Nov 11, 2007 12:18 PM
NightStalker
Jan 11, 2006 04:50 PM
MugenRioS2k1
Jan 8, 2006 01:06 PM
