Flashpro not showing DTC codes
Old Dec 5, 2009 | 11:07 AM
glagola1's Avatar
Default Flashpro not showing DTC codes
I've had a couple check engine lights pop up and when I go to check the code it doesn't display a number. I've data logged it and no error code shows when I review the data log either. The OBDII thing says that there is in fact a DTC.
What's the deal?
thanks
Old Dec 5, 2009 | 12:45 PM
Elroy's Avatar
Been there done that
You can check the Hondata forum and see the blunt answer I got or....
Look at the "Error Codes" window for the code and description. If you have a DTC in the OBDII Diagnostics and nothing in the Error Window then clear the DTC since you will never get it with the FlashPro. You need to record the event and replay it which will show in the error window the second you load the data log onto you laptop/pc.
J
Old Dec 7, 2009 | 06:14 AM
glagola1's Avatar
That's weak. So you need to be recording/datalogging as it happens? What's the usefulness in that?
Old Dec 7, 2009 | 06:19 AM
glagola1's Avatar
And... I already asked in that forum but no one has replied.
weenrock
Apr 6, 2018 01:12 PM
cvedral
Mar 26, 2013 06:36 AM
topcat7111
Sep 24, 2009 04:39 PM
Prolene
Jul 30, 2002 09:03 PM
