FlashPro and TPMS
Old Nov 12, 2010 | 02:59 PM
Harpoon's Avatar
Default FlashPro and TPMS
Is there a way to disable the tire pressure monitoring system with FlashPro? I have two sets of wheels on an '08 car and don't want to flip the sensors back and forth. If the car picks up on the absence of the sensors it goes into traction control mode. I don't want that.
Old Nov 16, 2010 | 03:29 PM
Harpoon's Avatar
I called Hondata today and asked them the question. The answer from the tech support guy was that TPMS is independent of the ecu and therefore, there is no control of it thru FlashPro.
Old Nov 16, 2010 | 04:02 PM
R1_Pilot's Avatar
Ask your dealership about this, but my Acura RDX supports two set of wheels. I have two sets with sensors and they both work.
The only downside is that you have to buy the extra sensors.
J
Old Nov 18, 2010 | 06:47 AM
irv_usc's Avatar
does your second set of wheels have the TPMS sensors inside? you should be able to program more than one set of sensors to the ECU.
dedonderosa
Feb 19, 2019 06:22 PM
s2k4life_az
Jul 11, 2013 08:26 PM
irv_usc
May 18, 2011 06:46 AM
QT_S2K
Nov 12, 2002 09:38 AM
minboost
Sep 16, 2002 07:18 AM
