FlashPro update enables external wideband O2
Old Mar 26, 2010 | 07:15 AM
Gernby's Avatar
Former Sponsor
Default FlashPro update enables external wideband O2
The beta version of FlashPro Manager 1.1.4.6 includes enhancements that allow the use of ECT2 or ELD as inputs for external wideband sensors. However, I haven't been able to find anything in the help documentation to indicate whether the external wideband can be used for closed loop operation instead of the OEM wideband, or if the data is just passed through to the datalogs. Has anyone tried this yet?
Old Mar 26, 2010 | 07:40 AM
scareyourpassenger's Avatar
Here is another thought. Using the WOT Fuel tables and setting leaner values of 12.5:1 you could use the wideband to control WOT.
Old Mar 26, 2010 | 07:44 AM
Gernby's Avatar
Former Sponsor
I don't understand this post. Did you mean to post in this thread?
Old Mar 26, 2010 | 07:51 AM
wadzii's Avatar
Banned
closed loop control at WOT dosnt work very well, most of the time the engine changes speed too quickly for it to work.
Old Mar 26, 2010 | 07:52 AM
devs2k's Avatar
I haven't been following FlashPro as much lately, but I downloaded the beta version and saw Boost Control settings. Can FPro now control boost??
Old Mar 26, 2010 | 07:58 AM
I may have been too deep in it. This is sort of related but since you would get greater accuracy from the wideband you could look at controlling WOT fuel levels thought the af targeting values in the WOT fuel tables.
In the Hondata manual for the WOT fuel tables.
[QUOTE]Important note:
Old Mar 26, 2010 | 07:59 AM
Now, this doesn't belong
Old Mar 26, 2010 | 08:29 AM
devs2k's Avatar
That's only for the Civic Si right?
Gernby's Avatar
Former Sponsor
I would only consider closed loop at WOT if it could be limited by gear (ie. only in gears 3-6), since the O2 sensor wouldn't respond quickly enough for closed loop to work in 1st gear.
Old Mar 26, 2010 | 08:30 AM
Gernby's Avatar
Former Sponsor
I believe boost control is now available on the S2000 FlashPro, but you can confirm it on the Hondata forum.
