FlashPro update enables external wideband O2
Old Mar 26, 2010 | 08:32 AM
devs2k's Avatar
Originally Posted by gernby,Mar 26 2010, 12:29 PM
I would only consider closed loop at WOT if it could be limited by gear (ie. only in gears 3-6), since the O2 sensor wouldn't respond quickly enough for closed loop to work in 1st gear.
They don't have any o2 sensors that react fast enough? I know Giles (Holyroller Dyno) was able to use the Innovative wideband coupled with the Emanage Ultimate for closed-loop o2 feedback. The green immobilizer key light would indicate when you are hitting an ideal AFR. I remember even in first/second gears, the green key would illuminate relatively quickly. Maybe not quick enough for FI, only NA?
Old Mar 26, 2010 | 08:44 AM
scareyourpassenger's Avatar
You would still tune the fuel maps to get close to the target value. The fine tuning would be part of the closed loop operation.
Old Mar 26, 2010 | 08:53 AM
Gernby's Avatar
Former Sponsor
If you want to see how quickly your O2 responds, move 2 fuel indexes very close to each other (ie. 3500 and 3501), and increase fuel of the first by a couple percent and decrese the fuel of the second by a couple percent. Then look at how sharp the transition appears in the datalog for each gear. I suspect that it will look like a cliff in 3rd gear, but a tiny wave in 1st. I also suspect that the wave will appear a few hundred RPMs higher in the RPM range than it does in 3rd gear.
Note: I haven't actually tried this, but that is what I think will happen.
Old Mar 26, 2010 | 08:57 AM
Gernby's Avatar
Former Sponsor
I don't think the issue would really be that the STFT would be a bit too big or a bit too small. I think that it might be a few hundred RPMs too late. Basically, by the time the ECU decides that the STFT needs to be +2%, the RPMs might have already climbed to a point where STFT really needs to be -2%.
Old Mar 26, 2010 | 11:35 PM
EliteTuning's Avatar
During wot, the ecu is in open loop. During closed loop operation (part throttle), the ecu adjusts for 14.7. With k-pro for example, you can disabled closed loop and tune part throttle to be leaner to safe more fuel and leave closed loop off. I tune part throttle to 15.5 af and wot for n/a at 12.8 af. Boost between 11.5-11.8 af
dsddcd
Nov 2, 2009 06:17 PM
Stoner_1
Jan 4, 2009 08:07 PM
Nobody
May 6, 2005 12:21 PM
