Greddy Emanage Ultimate Map
Old Jul 15, 2021 | 11:27 AM
Rustyshark's Avatar
Default Greddy Emanage Ultimate Map
Hello everyone.
I have a 2005 AP2 with a Science of Speed Stage 1 Supercharger Kit which comes with the piggyback FVM. I also have headers, invidia test pipe and a q300. I am in an emissions county so I need to be able to keep my OBD2.
I recently picked up a Greddy Emanage Ultimate so I could get the car tuned further and start upgrading the supercharger kit some. Problem is I am having a hard time finding people who actually tune this thing.
I haven't installed it yet as I am waiting on a harness. Does anyone have any maps that I could try out on this thing when I put it in that has a similar setup to mine? At least until I can find someone to actually tune it.
Many thanks ahead of time.
Jerry
my email is rustyshark@gmail.com if you have one you could send me.
Old Jul 17, 2021 | 06:30 AM
EOE's Avatar
EOE
What are your injectors?
Whats the boost level?
Octane?
You’ll need the following tools:
Do you have a WideBand?
32 Bit windows OS?
OBD2 scanner?
Old Jul 17, 2021 | 12:02 PM
Rustyshark's Avatar
stock injectors, 6psi, 93
have a aem uego, has windows, no scanner but I can get one
Octane?
32 Bit windows OS?
OBD2 scanner?
Old Jul 18, 2021 | 05:53 AM
EOE's Avatar
EOE
I can walk you through getting the map put together if you’d like. Or I can put one together for you. But you’d have to be extra cautious, do a number of test runs, each time making sure your AFR is in check @ WOT and OBD2 Bluetooth scanner will confirm that your fuel-trims are okay in part-throttle.
Send me a msg if you'd like to get more details or interested.
Old Feb 27, 2022 | 09:34 AM
soccaz34's Avatar
Has anyone been able to run Emanage and actually connect to the ECU with a Windows 10 running the program in compatible mode? I even tried emulating a windows XP 32bit and it wouldn't connect. The program would start up but couldn't connect to the ECU. I would like to get rid of the super old laptop I have been using to connect to the ECU.
Old Feb 28, 2022 | 09:39 AM
gotembro's Avatar
So I did a few things i build a Windows XP virtual box and that didn't work
But you can run the program in Windows XP mode on your Windows 10 desktop and plug it in it will work.
The program won't work right until you plug it in. I was trying to get it to work without plugging in the e manage once I did with a USB printer cable it worked fine.
Old Feb 28, 2022 | 12:34 PM
flanders's Avatar
I got it to work on Windows 7, a lot better than XP at least but not sure if Win10 is possible.
Old Mar 1, 2022 | 01:55 AM
EOE's Avatar
EOE
Never worked in compatible mode unfortunately, but any 32bit version of Windows works just fine.
Rashido
Nov 12, 2010 03:43 AM
2006ap2
Oct 6, 2009 05:53 PM
UpsFella
Dec 1, 2008 09:30 PM
ScottyBallistic
Oct 4, 2007 06:56 PM
F1fletcher
May 13, 2006 02:26 PM
