HELP! KPro Sensor Install
Old Jan 18, 2010 | 09:53 AM
jaundice's Avatar
Default HELP! KPro Sensor Install
Help. Hondata says all you need is a new crank sensor harness, but the new cam sensor I installed (per Hondata's website) has a 3 prong female end and my MY02 has a 2 prong female connector. I cannot find anywhere where anybody has changed this wiring harness. Did I get sent the wrong cam sensor?
Old Jan 18, 2010 | 10:36 AM
spectacle's Avatar
The new harness Hondata sends goes directly from the sensor to the ECU. It bypasses the stock harness completely
Old Jan 18, 2010 | 11:15 AM
jaundice's Avatar
Gotcha. Thanks
Old Feb 18, 2010 | 06:07 PM
jaundice's Avatar
Ok, more help needed. I finally received the sensor harness wire from the seller I bought the Kpro from. Of course, I have no instructions, so I need to know which plug goes to which sensor. The harness is bundled together and has a sensor plug 2/3 of the way down and then has a sensor plug at the end. Which one goes to the cam sensor and which one goes to the crank sensor?
Old Feb 23, 2010 | 08:30 AM
Spunkster's Avatar
The long one should be labeled crank.
rjbecker12
Oct 5, 2012 08:29 AM
ap1chick
Oct 12, 2008 09:09 AM
