Hondata 4 bar MAP sensor
Old Mar 16, 2010 | 09:37 PM
D1sclaimer's Avatar
Default Hondata 4 bar MAP sensor
I bought a second hand Hondata 4 bar MAP sensor with only the sensor and no instructions. Figured it'd just be switching it out and changing some values in the AEM EMS. I searched for the corrected values on here for the Hondata 4 bar MAP sensor and the AEM EMS 1052 and couldn't find much. I ended up trying to use the Omnipower 4 bar MAP sensor values.
min voltage .08
max voltage 4.88
scalar 3.8
load offset 15.0
filter 10
frequency 0
These got the sensor to read 102.xx Kpa where as right before, the stock sensor was reading 99.52. Both with the car off.
I tried to start the car with the Hondata 4 bar MAP sensor and the above values and I could not get the car to start. I swapped on the stock sensor after, loaded up the stock values and it fired right up.
Am I missing something? Do I need to tweak anything else for it to work?
F1TwoThousand
Oct 15, 2018 08:54 AM
kosdali
Κινητήρας - Μετάδοση - Περιφερειακά
Dec 11, 2014 03:10 AM
Prokaw875
Oct 1, 2012 02:29 PM
