How many people have gotten a CEL from flashpro
Could hondatas software cause this?
i have an 07 with no secondary o2. what is the code it is throwing? system too lean? reset your light and do a datalog of normal driving and cruising at a steady speed. go back and check your air fuel ratio which should be @ 14.7 and also check your o2 voltage to see if its jumping all crazy or flat lining out. you can troubleshoot by just datalogs!
nevermind about the HFC i swapped the stock cat on logged ~15 miles and still no "readiness"
So all the folks that change their sensor had the problem resolved? It seems like an incompatibility between FlashPro and the old type of sensor, mine had 20k when it happened and a week after the flash, thee odds of being o coincidence are quite low..
The original 06 sensors were recalled. The official letter from Honda is floating around somewhere in this forum.
