How many people have gotten a CEL from flashpro
Old May 27, 2011 | 07:10 AM
JmanS2k's Avatar
Default How many people have gotten a CEL from flashpro
I was about to order a FP and I was wondering how many peoples 06's have thrown a CEL from their o2 sensor? I read a bit of info about it a few months ago but, if I do get a CEL what's the Honda part number for the correct o2 sensor? Would I still buy a 2006 sensor or would I buy a new version?
Old May 27, 2011 | 12:41 PM
Biohazard's Avatar
you can turn it off on flashpro. no worries
Old May 27, 2011 | 03:36 PM
pde27's Avatar
i think he is talking about the primary o2 sensor that all the 06 cars were having issues with. there is a TSB for it but since i dont work there anymore i cant look it up for you. maybe someone that still works there can chime in.i have an 08 and have no issues but i think they fixed it by then.
Old May 27, 2011 | 05:58 PM
steelers743's Avatar
I got the CEL maybe 3 times when I first installed flashpro but I just reflashed the ECU and havnt had the problem again for half a year
Old May 27, 2011 | 06:37 PM
ViperASR's Avatar
I got a CEL and had to replace the primary O2 sensor.
Old May 28, 2011 | 02:14 AM
JmanS2k's Avatar
Yeah this is what I was talking about. I don't have a warranty but, if I need a new primary o2 sensor what's the correct part number? I just didn't know if I would need a newer version to fix it or just another 06. I've got access to a scan tool so I'll know what code it is if it comes up.
Also, where in the program does it allow you to clear a CEL from a test pipe? Or does it just clear when you reflash?
Old May 28, 2011 | 03:13 AM
bastanu's Avatar
I got one one week after Flashpro install, than went away...I may need the new sensor, the car has power train warranty but I am not sure if the sensor qualifies for replacement.
Old May 28, 2011 | 04:39 AM
UC Gordon's Avatar
I have gone 6 months with no CEL on my 2006.
Old May 28, 2011 | 05:34 AM
06S2k07Si's Avatar
Informational post here:
https://www.s2ki.com/s2000/topic/747...o2-cat-delete/
Brian
Old May 28, 2011 | 05:44 AM
JmanS2k's Avatar
The CEL doesn't cause the car to go into safe mode does it? And I never got an answer on reseting the CEL with FP. Does it reset when you reflash or is there a separate option you need to setup before you calibrate your reflash?
