How safe
Old May 18, 2011 | 06:34 AM
DG's Avatar
DG
Default How safe
I finally got around to actually use my flashpro that's been sitting at home for months. I used the mugen base map and am now wondering how safe it is. The S has a 70mm hfc, greddy se dual and k&n fpik. I know I should get a real tune, but I can't justify paying $500+ for a car that I drive 2-3 a month. Is it safer to just leave the oem tune or am I ok with running the mugen base map (or any other of the base maps it comes with)?
Old May 18, 2011 | 07:09 AM
DFWs2k's Avatar
log some pulls and check your a/f
Old May 18, 2011 | 07:28 AM
DG's Avatar
DG
can it be done in 2nd gear?
Old May 18, 2011 | 07:34 AM
scareyourpassenger's Avatar
Checking knock counts for a 30min drive should work in general. One 3rd gear pull for fuel and that should tell you how far it is off.
I would run the toda tune since you have a HFC.
Old May 18, 2011 | 07:44 AM
Gernby's Avatar
Former Sponsor
I agree with ScareYourPassenger. The Mugen calibration is NOT the right choice for your setup. The Toda calibration is probably going to be a better bet.
Old May 18, 2011 | 08:04 AM
DG's Avatar
DG
No Idea how to check that. So I datalog right before going wot in 3rd, correct? Can it be done in 2nd?
Will change to that one
Old May 20, 2011 | 06:38 AM
DG's Avatar
DG
Ended up just purchasing e-tuning from evans to be safe and not have to worry.
Old May 30, 2011 | 08:45 AM
deepbluejh's Avatar
Question for you guys. Here are my mods:
AEM V2 CAI
70mm Berk HFC
Q300 70mm dual exhaust
Would a modified Mugen tune be the best option for me? The mugen tune is for an intake, header, and exhaust. That appears to be a better match than the Toda tune, which was just for a header. Yes, the default VTEC switch for the Mugen is a little high (5400), but if I dropped that down to 4400rpm or so, wouldn't that be a better option?
EastLondonS2K
Mar 26, 2015 03:01 AM
JoeyBalls
Apr 13, 2009 04:20 PM
3William56
Sep 17, 2008 06:14 AM
soulcrew
Oct 16, 2004 02:16 AM
radron
Dec 1, 2003 02:26 AM
