Infinity changes when swapping from 3 bar to 4 bar MAP sensor?
Old May 16, 2020 | 07:04 PM
treimche's Avatar
Default Infinity changes when swapping from 3 bar to 4 bar MAP sensor?
I recently switched from the SOS 3 bar MAP sensor to a Skunk2 4 bar MAP sensor. I'm wondering if there is anything that needs to be changed in the AEM Infinity ecu settings in order for the new MAP sensor to work properly? Just trying to get everything ready for startup with the new block and before going to get tuned.
Old May 16, 2020 | 09:31 PM
afzan's Avatar
yes you'll need to change this:
infinity tuner -> wizards -> wizard -> basic sensors -> map sensor setup ->
Old May 17, 2020 | 06:52 AM
treimche's Avatar
Hey thanks for that. I was going to look in the SOS Infinity instructions to see what I had to set up for their map sensor initially also. Are you pretty well versed in the Infinity ECU?
Old May 17, 2020 | 09:58 AM
afzan's Avatar
I know my way around but I'm far from being an expert
jun11
15
Jul 21, 2019 03:55 PM
SamWhited
Feb 20, 2019 08:33 AM
mikemo
Apr 27, 2017 09:09 AM
decepticondc5
Feb 28, 2017 06:45 AM
WVCR-V
Jul 20, 2016 12:21 PM
